why does the value of MSTATUS register change in this way? base on RT685
516件の閲覧回数
melanie
BOARD_InitBootPins();
BOARD_BootClockRUN();
BOARD_InitDebugConsole();
result=I3C->MSTATUS; 0x1000
PRINTF("\r\nI3C master read sensor data example.\r\n");
I3C_MasterGetDefaultConfig(&masterConfig);
masterConfig.baudRate_Hz.i2cBaud = EXAMPLE_I2C_BAUDRATE;
masterConfig.baudRate_Hz.i3cPushPullBaud = 12500000U;
masterConfig.baudRate_Hz.i3cOpenDrainBaud = 4000000U;
masterConfig.enableOpenDrainStop = false;
I3C_MasterInit(EXAMPLE_MASTER, &masterConfig, I3C_MASTER_CLOCK_FREQUENCY);
result=I3C->MSTATUS;0x1101
why the value change?
0x1101 means the slave holds the SDA low, right? why?
is this value change right? why?
タグ(1)
505件の閲覧回数
There is Slave Request in your I3C bus.
Alice
