problem USB HID Generic interrupt
273件の閲覧回数
dskim2
When I built and ran the usb dev_hid_generic_bm_cm7 sample source on the RT1170 EVK board, it worked without problem.
However, when I added and activated linkscrip to delete and record data in QSPIFlash, a phenomenon occurred in which the board was not recognized when connected to the PC USB port.
As a result of debugging the USB_OTG1_IRQHandler interrupt function, a phenomenon occurred in which kUSB_DeviceEventGetStringDescriptor was not received after receiving the kUSB_DeviceEventBusReset response.
Upload the linkscript file in the attachment.
2 返答(返信)
226件の閲覧回数
dskim2
Thanks for your response.
I modified the script and moved the execution parts of *flexspi_nor_flash_ops.o(.text*) and *fsl_flexspi.o(.text*) to another SDRAM, but it did not solve the problem.
My requirement is to use QSPI Flash and USB HID communication function simultaneously.
Upload the the source file in the attachment.
230件の閲覧回数
EdwinHz
Hi @dskim2,
I believe the following blog post will prove very useful for your inquiry. Placing Code in Sections with managed GNU Linker Scripts | MCU on Eclipse
It goes into the details on how to adequately manage linker scripts with MCUXpresso. Let me know if it helps.
BR,
Edwin.
