_lwip_ping_bm_
_lwip_ping_bm_
1,259件の閲覧回数
tomas2
I am useing mimxrt 1060 EVK and i want to try ethernet function.  SDK evkmimxrt1060_lwip_ping_bm_ and I did all needed settings but output on terminal isn't right.
First picture shows how it should look like and the second pic show how it realy looks.
Thank you for your ideas.
3 返答(返信)
1,236件の閲覧回数
jeremyzhou
Actually, the demo works well on my board.
So I'd like to suggest you download the latest version of the SDK library and follow the readme to set the hardware environment.
TIC
1,192件の閲覧回数
tomas2
I have dowloaded the latest version of the SDK and also I did everything from the readme.
But as i see you are using 1050 EVKB board but my board is 1060 EVK and I am using Jlink debuger.
And I forgot to mention when I try to ping board from PC using command prompt everything works right.
Thank you for your help.
1,155件の閲覧回数
jeremyzhou
With the outbreak of Covid-19, I have to work at home and I don't have the MIMXRT1060 EVK board on hand, so I try to use the MIMXRT1050 to replicate your phenomenon.
TIC
