i.MX RT1010 FPU multiply
2,257 次查看
danielmilutinov
I am looking for an example on how to use FPU multiply instructions on the i.MX RT1010. On the Texas Instruments TM4C series Cortex-M4F the floating point unit is activated, then the 2 float factors are passed to an assembly function that multiplies the values in registers S0, S1 using the FPU multiply instruction VMUL and returns the product to the calling function.
Is it a similar process for the i.MX RT1010? Is there an example in the SDK or could someone please give me an example?
标记 (1)
2,074 次查看
mjbcswitzerland
Specialist V
As long as you have your compiler set up correctly all operations that can be done with FPU instructions should automatically be done so.
Check that when a C-file is compiled the compiler flags that are seen include
-mfloat-abi=hard -mfpu=fpv5-d16
and check some code in disassemble mode to confirm that it works as you expect.
Also be careful with the use of casts in code to ensure that the types used in calculations are as intended - take a look at Eric Styger's discussion of FPU operations on Cortex-M4F but don't forget that the FPU in double precision in the i.MX RT and so doesn't suffer the same way when not controlling the type.
Although the compiler may make use of the FPU is is still up to the start-up code to enable it otherwise the first attempted access will fail, however I expect most start-up code will enable it per default.
In products where FPU operations are not needed (and the compiler is appropriately informed never to use HW FPU methods)  the FPU can be disabled and interrupt latency improved since less registers need to be saved - meaning that start-up code is best made conditional on whether HW FPU utilisation is intended by the developer or whether the developer prefers to avoid it to benefit from improved interrupt response time in a predominantly integer environment.
Mark
[uTasker project developer for Kinetis and i.MX RT]
4 回复数
2,075 次查看
mjbcswitzerland
Specialist V
Mark
2,074 次查看
danielmilutinov
Hello Mark,
Thank you for your detailed answer. I didn't see the FPU option in the new project wizard and as you pointed out, all operations involving floats that can be done with FPU instructions are done so automatically if the single precision FPU option is chosen.
On page 28 of the reference manual (found here) it states that the FPU on the i.MX RT1010 is single precision.
2,074 次查看
mjbcswitzerland
Specialist V
There is a some confusion over the FPU in the 1010 and I haven't used this part enough to have noticed whether double precision would fail or not.
As reference, these are from the 1010 and 1015 User manuals
1010:
But in their Data sheets:
1010:
1015:
If one selects these two parts in IAR both cause IAR to set double precision FPU (although one can manually change the setting later)
If one uses MCUXpresso SDK examples the 1010 is set with
-mcpu=cortex-m7 -mfpu=fpv5-sp-d16 -mfloat-abi=hard -mthumb
and the 1015 with
-mcpu=cortex-m7 -mfpu=fpv5-d16 -mfloat-abi=hard -mthumb
Since I tend to use the data sheet, rather than user's manual as priority when in doubt, and it states full-featured FPU for both I originally though all i.MX RT has the double precision FPU. Also I think that IAR must believe this too. But, based on SDK reference projects, the SP setting is used in the 1010 case, and so it most likely correct.
Without specifically testing I tend to agree that the i.MX RT 1010 is an exception in not having double precision support, in which case Eric's blog is in fact very relevant to it!!!! I also think that the data sheet to the 1010 part is either wrong or misleading.
Mark
2,074 次查看
jeremyzhou
Hi Daniel Milutinovic,
1) Is it a similar process for the i.MX RT1010? Is there an example in the SDK or could someone please give me an example?.
-- In general, it needs two steps to do the multiply operation via FPU module on the i.MX RT1010, firstly, it should enable the FPU module, then utilize the CMSIS-DSP to do the multiply operation.
TIC
