i MX RT 1060 LCDIF pin mapping
abilashjoseph
I was looking on the LCDIF of iMX RT 1060. The data line selection for different format I didn't saw in the LCIF section. I saw the same for Camera interface. attached the details for reference. Is this same pin mapping will be same for LCDIF also?
kerryzhou
Hi @abilashjoseph ,
  This is the LCDIF pin situation:
Then, the detail data format is related to your LCD pin connect to your LCD situation.
More details, you can refer to:
AN12302
https://www.nxp.com/docs/en/application-note/AN12302.pdf
Wish it helps you!
Kerry
