Use ENET_SetMII() function without disabling Ethernet MAC
845 次查看
ombra32
I need to dynamically change MAC controller speed and duplex, based on values auto-negotiated by PHY at each link up.
In iMXRT1176 SDK there is a function named ENET_SetMII(), created exactly with that purpose:
 * brief Sets the ENET MII speed and duplex.
 * This API is provided to dynamically change the speed and dulpex for MAC.
 * param base  ENET peripheral base address.
 * param speed The speed of the RMII mode.
 * param duplex The duplex of the RMII mode.
void ENET_SetMII(ENET_Type *base, enet_mii_speed_t speed, enet_mii_duplex_t duplex)
I've tried it on my code, and it works like a charm!
But iMXRT1170 Reference Manual states that TCR->FDEN register (changed by ENET_SetMII() function) can be modified only with ECR->ETHEREN = 0 (Ethernet MAC disabled).
So, now the question is: is really safe to use ENET_SetMII() function to dynamically change speed and duplex of MAC controller, without disabling it?
Marco
824 次查看
jeremyzhou
1) Is really safe to use ENET_SetMII() function to dynamically change speed and duplex of MAC controller, without disabling it?
-- No, I'm afraid not, it's a risk to do it.
Have a great day,t
TIC
813 次查看
ombra32
Ok, so what is the best suggested way to manage ENET MAC after PHY re-link?
805 次查看
jeremyzhou
Thanks for your reply.
1) So what is the best suggested way to manage ENET MAC after PHY re-link?
-- It seems like that it needs to reInitialize the ENET module.
TIC
