Trying to develop a USB DAC application with RT1160.
Build project from SDK example:
evkmimxrt1160_dev_composite_hid_audio_unified_freertos_cm7
SDK version: 2.13.0
Test device:
While connecting with iPhone. Run into a situation where audio playback become intermittent.
Reproduce steps:
Attaching a sniffer tool. I found that iPhone is always sending setInterface request after step4.
Control Groups:
- Yamaha AG-03
- Shure X2U
don't not have this issue.
已解决! 转到解答。
Hi @SeenFan ,
I have finished your 1KHz audio testing on my side, my wave is good:
My test method is:
Board USB J20 connect to the PC will emute USB AUDIO+HID DEMO interface.
1. Use window media player play your 1Khz
Then the board speaker will output the 1KHZ sound
2. Use the Audacity to record the sound from the PC mic, my surrounding is quite, so, it can record the board speaker sound, then I check the wave, totally OK.
You can see:
The original one and the record one are the same.
What's the code you are testing?
Use my previous project release version:
If you use the debug version to work, set the symbols NDEBUG.
I attach the new project again.
What's the product you want to use, if you also want to play in the PC and iphone for long time, do you mind to change to the Full speed instead of the High speed, then both PC and the iphone will stable, as my iphone 7 is full speed, no issues.
Kerry
Hi @SeenFan ,
If you still have issues, please test my new project which I share you right now:
Any updated information, kindly let us know.
Kerry
Hi @SeenFan ,
So, your issue is resolved, right?
Please do more long time testing, if it is really resolved, please let me know, and our expert Tim Wang who help you do the deep research also very concerned your cases, do you mind also tell us, what's the product you are design?
Kerry
I try to regenerate this issue with iphone, while looks like iphone could not recognize RT1160-EVK board as USB audio device.
I use a iMac PC works with RT1160-EVK board normally.
Could you show us how do you connect iphone with RT1160-EVK board?
If we need to install any APP to make USB device be recognized? Thanks.
best regards,
Mike
