I'm designing an i.MX RT1170 application board.
I'm not sure what value should I set on Turnaround time, SRAMCRn[TA].
How does the value of SRAMCRn[TA] affect bus timing if I use ASYNC SRAM on SEMC bus by Non-ADMUX Mode?
Solved! Go to Solution.
Hi @Eugene3 ,
Actually for this case , no TA configuration is needed. Please kindly refer to the following for details.
Kan
Hi @Eugene3 ,
Kan
