Setup UART-RS485 without using DMA for i.MX RT1170
1,000 次查看
JayCao
Dear support team,
I am developing a project that uses several LPUARTs for RS232 and RS485.
For RS232, I used it same as the sample source.
However, I hard to find the RS485 configuration on the fls_lpuart.h library.
I read the guide for implementing the RS485 on the i.MX RT series
https://community.nxp.com/t5/NXP-Designs-Knowledge-Base/Implement-High-Speed-RS-485-Application-with...
but this one uses DMA to do that.
Could you help to guide me on how to use that without DMA?
Thanks and BRs
标记 (3)
871 次查看
Kan_Li
Hi @JayCao ,
The UART module just acts as it is, the RS485 is supported with an external transceiver as mentioned in https://community.nxp.com/t5/NXP-Designs-Knowledge-Base/Implement-High-Speed-RS-485-Application-with... , whether DMA is used or not.
Hope that makes sense,
Kan
4 回复数
906 次查看
JayCao
Are there any updates for this question?
977 次查看
Kan_Li
Hi @JayCao ,
If you don't prefer to the DMA operation, maybe you can start with the polling or interrupt mode, and we provide such kind of demos in the SDK, you may refer to SDK_2_14_0_MIMXRT1170-EVK\boards\evkmimxrt1170\driver_examples\lpuart for details.
Hope that helps,
Kan
968 次查看
JayCao
Hello Kan Li,
Thanks for your answer!
I had seen the lpuart driver examples.
But it looks like support for RS232, which part should I change to use for RS485?
Thank you
872 次查看
Kan_Li
Hi @JayCao ,
Kan
