Please Recommend a 7 inch LCD for RT1170 Evk Board.
Provide the link to buy online.
Jagadeesh
Were you able to find the 7" display and use the same? We have a similar requirement and looks like 2 Lane 7" MIPI displays are hard to find.
Thanks for your interest in the NXP MIMXRT product, I would like to provide service for you.
To the RT1170, as you know, it can support :
So, if you want to use the 7 inch LCD, you need to check the LCD company, and find which 7 inch LCD can support MIPI LCD interface, as you know, MIPI is the standard interface, if that LCD can support this interface, it can be used with RT1170.
Now, we mainly recommend the MIMXRT1170-EVK board related LCD:
https://www.nxp.com/part/RK055HDMIPI4M#/
Other inch LCD, you need to select it by yourself.
Wish it helps you!
If you still have questions about it, please kindly let me know.
Kerry
