RT1176 ENET_QOS RMII连接问题
918件の閲覧回数
Vincent_11_CWS
问题:我们想使用RT1176 ENET_QOS的RMII模式来连接PHY,其中PHY上的RMII_CRS_DV这个引脚应该与RT1176 ENET_QOS的哪个引脚相连呢?在RT1176的datasheet和参考设计中都有描述,如果使用ENET/ENET1G的话,RMII_CRS_DV可以连接到RX_EN上,但是关于ENET_QOS并没有这样的描述,我们该如何设计呢?
3 返答(返信)
890件の閲覧回数
vicentegomez
Would be possible that you put your question in English?
871件の閲覧回数
Vincent_11_CWS
I have some questions regarding NXP RT1176, which would need your clarifications. When we apply the RMII mode of RT1176- ENET_QOS, which pin should CRS_DV in PHY connect to? According to the description in the datasheet, it would connect with RX_EN in ENET/ENET1G. However I can’t find any contents in ENET_QOS of RT1176.
863件の閲覧回数
vicentegomez
you can check the  mimxrt1170-evk schematics on the next link
https://www.nxp.com/webapp/Download?colCode=MIMXRT1170-EVK-DESIGNFILES
I hope this will help you
