RT1170 ethernet can't work when use OCRAM for data
605件の閲覧回数
zyz
I am using MIMXRT1170-EVK board to debug ethernet, the demo routine used is lwip_tcpecho_freertos_cm7, the program works good, but when I try to use SRAM_OC1 as data storage area, the network can't working, can anyone help me?
The following are the default settings for the demo routine,it's work good
When I try to change to the following settings,the ethernet can't work:
594件の閲覧回数
kerryzhou
Hi @zyz ,
   This should relate to the cache.
   You can check this application note:
https://www.nxp.com/docs/en/application-note/AN12042.pdf
  Please read it carefully.
Kerry
