RT1170 Example of accelerometer
894件の閲覧回数
dskim2
I have an RT1170 EVK board.
I looked for accelerometer demo source in MCUXpresso IDE, but it doesn't seem to be there.
Where can I get the demo sources?
Best Regards
タグ(1)
6 返答(返信)
883件の閲覧回数
Gavin_Jia
Hi @dskim2 ,
Thanks for contacting NXP tech support!
Could you describe in more detail the demo you are looking for? For graphics acceleration or something else?
Gavin
875件の閲覧回数
dskim2
Looking at the demo board circuit diagram, FXLS8974CFR3 is installed, I need a demo source that can use this accelerometer device.
851件の閲覧回数
Gavin_Jia
Hi @dskim2 ,
The examples in the current SDK do not include a demo that uses this accelerometer, but provide component implementations: SDK_2_15_000_MIMXRT1170-EVK\components\fxls8974cf
Other than that, here's a project that implements a driver for it that should help you, I've packaged it up as an MCUXpressoIDE project for you to check out in the attach files, the original link is here: https://github.com/nxp-appcodehub/ap-ml-state-monitor/tree/main
Hope it helps!
Gavin
525件の閲覧回数
VassiliN
I downloaded this sample project to be used with MIMXRT1170-EVKB which has the same sensor according to the HW Guide:
MIMXRT1170EVKBHUG
MIMXRT1170 EVKB Board Hardware User Guide
Rev. 4 — 11 June 2024
2.16 Sensor
U115 on the EVK board is a 3-axis MEMS accelerometer. Sensor FXLS8974CFR3.
When I run the project I am getting this in Terminal:
Starting Application:
CPU: 996000000 Hz
Application version: 1.0.0
MPP version: MPP_VERSION_1.0.0
Inference Engine: TensorFlow-Lite Micro
FXLS8974 Sensor Initialization Failed
Failed to add accelerometer Fxls8974
Error building application pipeline : ret 3
CPU: 996000000 Hz
Does EVKB board requires some different settings for the Fxls8974?
845件の閲覧回数
dskim2
Thanks for your reply
When I ran the source in MCUXpresso for debugging, the following error occurred.
How can I solve this?
Best Regards
842件の閲覧回数
Gavin_Jia
Hi @dskim2 ,
This demo is working and was able to build successfully on my end. But debug requires additional hardware. So you can adopt it as a reference implementation for an accelerometer driver. It should fit your needs.
Gavin
