RT1060 where is the ADCSC1 register defined?
funbotix
In the application information for the ADC there is a section called sampling error in the sources of error section. In the sampling error section a recommendation is made to write to the ADCSC1 register. I cannot find that register in the processor reference manual or processor header files. Can someone please point me to where I can find information about this register, or tell me which other register I should be writing to for this error scenario?
Thanks!!
CarlosGarabito
ADCSC means  ADC Status and Control, this is conformign in the next form
And you can find in the RT1060 on ADCH you can find more information on the next documentation
66.8.1 Control register for hardware triggers (ADCx_HC0)
https://www.nxp.com/docs/en/application-note/AN3731.pdf
https://www.nxp.com/docs/en/data-sheet/MC68HC908JL16.pdf
Hava a good day
