1、Hello!Since your latest RT1052 SDK package only supports compiler version 6, could you please check the previous SDK package which can support compiler version 5?
2、How does RT1052 SDK 2.7.0 support rt-thread, since cortex-m7's context_rvds.s currently only supports compiler version 5
Hi ,
for the opportunity to serve you.
1) I'm not very clear with this question, what's compiler do you talk about?
2) Until now, the RT-Thread is not included in the SDK library, it needs the developer to port it by himself, otherwise, use the software library provided by the RT-Thread team.
TIC
Hi ,
Thanks for your clarification.
Right now, the previous versions of the SDK library are unavailable to be download on NXP website, in further, the SDK library is too large to share in the community, so I'd like to suggest you use the search engine to look for other downloading sources.
TIC
