RT1052 LPUART FIFO depth is only 1?
1,790 次查看
lixiaotian
the LPUART Parameter Register (PARAM) is read as 0. So what is the meaning of the fifo?
5 回复数
1,503 次查看
1277185193
1,503 次查看
jeremyzhou
Hi li xiaotian,
Please check the LPUART[FIFO] register.
TIC
1,503 次查看
1277185193
Excuse me ...How to change the fifo depth? This field is read only......B8JKEAKPH0~9X6(7E_{784D.png
1,503 次查看
jeremyzhou
Hi 卢 鲲,
Thanks for your reply.
It's not able to customize to configure the depth of the buffer, you only can enable the buffer or discard this feature.
TIC
1,503 次查看
1277185193
  • OK!  Excuse me ......Are you an official with NXP ?
    It's so unbelievable...Why are there so many options of fifosize?
