RT1020 Errata link points to rev1 instead of rev2
627 次查看
rshipman
If you go to the webpage "i.MX RT1020 Crossover MCU with Arm® Cortex®-M7 core", the Errata section says that the latest revision is Rev 2. The link takes you to Rev 1. I know that Rev 2 exists as I have it, but the link needs to be fixed please.
https://www.nxp.com/products/processors-and-microcontrollers/arm-microcontrollers/i-mx-rt-crossover-...
Many thanks,
Ronnie
612 次查看
jeremyzhou
Yes, the link is wrong, I'll report the problem.
TIC
