NXP MIMXRT106 - PXP processing engine and emWin compatibility
849件の閲覧回数
nandlol
Hello everyone, my name is Fernando.
I need to implement a GUI application on a LCD 4.3 inch TFT 480*272 pixels with LED Backlight and touch panel.
The MCU target is the NXP - MIMXRT1064CVJ5B with the built-in PXP (PXP pixel pipeline: 2D graphics and pixel/image) processing engine. The reference IDE is the µVision IDE - Keil.
I would like to know if the SEGGER emWin library fully supports this PXP processing engine or what are the incompatibly points, if necessary.
Thanks a lot,
Regards.
3 返答(返信)
836件の閲覧回数
jay_heng
You can refer to simple emWin demo in SDK:
\SDK_2_x_x_EVK-MIMXRT1064\boards\evkmimxrt1064\emwin_examples\emwin_gui_demo
The panel used in demo is https://www.nxp.com/part/RK043FN66HS-CTG#/
818件の閲覧回数
nandlol
thanks for the tip.
I looked into the example, but is not clear for me if the example takes advantage of the PXP peripheral or not.
I've more interesting to understand if the emWin library can be used exploiting the PXP accelerator.
Can you you link me some other examples or application notes that highlighted this point please?
793件の閲覧回数
CarlosGarabito
