MX RT 1170 Ethernet ports RMII support
1,430 次查看
ereuveni
Hi everyone,
Looking into the MX RT 1170 datasheet, it states clearly that the 1G port support RMII interface.
However, it's not clear to me if the other ENET ports (10/100) support RMII as well.
Can someone please clarify?
I'm looking for an MCU with minimum 2xENET ports what supports RMII.
Thanks!
1,414 次查看
PabloAvalos
Hi @ereuveni
Thanks a lot for reaching our technical support and for giving us the opportunity to serve you.
Regarding your request, I would like to inform you that effectively RT1170 on Reference Manual mentions that both ENET ports support RMII operation on Page 3611.
Hope it helps! And please let me know if you have any other concern I can happily assist you with,
Best Regards.
Pablo Avalos.
1,415 次查看
PabloAvalos
Hi @ereuveni
Best Regards.
Pablo Avalos.
1,400 次查看
ereuveni
Thanks @PabloAvalos for your quick response!
1,377 次查看
PabloAvalos
Hi @ereuveni
You're very welcome. Please let me know if you have any other concern I can help you with. Otherwise, I will proceed to close this ticket and feel free to open a new one if you need further support.
Thanks a lot!
Best Regards.
Pablo Avalos.
