MCUxpresso IDE does not detect cm4 on MIMXRT1160-EVK
I am getting to grips with the 1160. For a first test, I loaded various examples. I noticed that examples with cm4 do not work because the correct target is not found. Strangely, however, programmes where cm7 and cm4 are linked do work.
How can I solve this issue?
已解决! 转到解答。
I found an answer by my self under the following link:
It's a brief overview for the RT1170 but those MCU's seem to be similar in that case.
