Trying to find if there is existing drivers/code-support to read/write to usb thumb-drives.
I could use either LPC55S69 or i.MXRT106x
(please let me know which host stack that would be consider most mature)
Feature needs:
- usb host, enumerate a Mass-storage usb device
- read/write to a filesystem, i.e. FAT32 (preferably also HFS+/ext2)
could you be more clear about it? the example no works for you as you want? the example no works as a host? o what are you talk about?
Could you please help me check the following posts?
https://community.nxp.com/t5/i-MX-RT/iMX-RT-USB-Host-msd-fatfs-do-not-work-well/m-p/1378884#M17334
By any chance, does this works for you ?
