IAR "Fatal error: Failed to connect to CPU" MIMXRT1060-EVK
3,226 次查看
nsohacki
After flashing a program with a possibly bad linker file to this board, my debugger can no longer connect to the processor. I read that some MCUs have an ISP mode where it allows the debugger to take control again. I don't see that for this MCU though.
标记 (2)
4 回复数
2,986 次查看
nsohacki
Support helped me in a ticket with this one. Turns out I had to erase the flash by setting the boot configuration to Serial Downloader (via the boot configuration pins) and using this tool: https://github.com/JayHeng/NXP-MCUBootUtility to erase the flash. Don't forget to change the boot configuration back to whatever it was set to. Also note that the tool expects the board to be connected via the USB OTG port so that it can access it as a HID device.
2,986 次查看
imxrtuser
Senior Contributor I
in my case for the RT1020 and RT1050 instead of using NXP-MCUBootUtility I always changed the boot configuration to something not used and then run the flexspi hyper flash/nor example from internal SRAM -> the examples erase the complete flash memory if running from internal SRAM.
Kind regards,
Stefan
2,986 次查看
kerryzhou
Hi Stefan,
    The internal RAM to erase the external flash also works. Thanks for your sharing.
    In fact, you just need to erase the external flash.
Kerry
2,986 次查看
kerryzhou
Hi Nicholas Sohacki ,
    Thanks for sharing the ticket reply in the community.
    MCUBootUtility also support the UART, not only HID.
    Wish it helps you!
  If you have the new questions in the future, welcome to create the new case, thanks.
Kerry
