I.MXRT1020 Maximum Audio channels counts in TDM mode
已解决
跳至解决方案
477 次查看
sheldonchin
As the subject, what is the maximum number of audio channels (24bit/96kHz) supported by I.MXRT1020 if using TDM mode?
Sheldon
1 解答
465 次查看
kerryzhou
Hi @sheldonchin ,
  To SAI TDM, each data line channel number is 32ch.
Wish it helps you!
Kerry
在原帖中查看解决方案
1 回复
466 次查看
kerryzhou
Hi @sheldonchin ,
Wish it helps you!
Kerry
