I.MXRT1020 Maximum Audio channels counts in TDM mode
sheldonchin
As the subject, what is the maximum number of audio channels (24bit/96kHz) supported by I.MXRT1020 if using TDM mode?
Sheldon
kerryzhou
Hi @sheldonchin ,
  To SAI TDM, each data line channel number is 32ch.
Wish it helps you!
Kerry
kerryzhou
Hi @sheldonchin ,
Wish it helps you!
Kerry
