How to use EMMC in RT1052?
1,330 次查看
meiweil
What is the difference between SD and EMMC on setting?
      Thanks!
标签 (2)
标记 (1)
1,126 次查看
Rita_Wang
The SD/MMC/eSD/eMMC/SDXC boot can be performed using the USDHC ports. The emmc support 4-bit and 8-bit data bus. For the 4-bit the emmc is the same design with the SD. The emmc design is almost the same as used in i.MX6 series use.  Hope this can do help for you.
Have a nice day
Rita
