How to setup Wi-Fi Direct (p2p) in RT1170-EVK
1,067件の閲覧回数
IronsmithWu
I want to use RT1170-EVK together with IW612 or 88W8987 to setup Wi-Fi Direct communication with my Android phone.
Does the MCUXpresso_SDK_WLAN_Driver support Wi-Fi Direct?
タグ(3)
4 返答(返信)
1,053件の閲覧回数
ramprakash09
It is important to note that the support for Wi-Fi Direct (or peer-to-peer) communication is dependent on the specific Wi-Fi module you are using. In this case, both the IW612 and 88W8987 modules do support Wi-Fi Direct.
1,036件の閲覧回数
IronsmithWu
Thanks a lot.
I want to use 88W8987 with i.MX RT1170, so I download the SDK: SDK_2_14_0_MIMXRT1170-EVK.
I read the document: MCUXpresson_SDK_WLAN_Driver_Reference_Manual.pdf, and I also check the example: MIMXRT1170-EVK-wifi_cli_cm7, But I can NOT find enough information about how to setup wifi direct communication.
Is there any documents or examples?
960件の閲覧回数
nxf77486
Thank you in advance for contacting NXP support.
As this was mentioned before Wi-Fi Direct is supported by the 88W8987 (this could also vary depending on the module maker), but this feature is not supported on the RT1170 neither the SDK support this feature.
The list of the supported features on the SDK is located on the SDK documentation docs->wireless-> Release notes.
Please let me know if there is anything else where I can help you.
938件の閲覧回数
IronsmithWu
Thanks for your information. I am so sad to hear that, it means I have to change my design.
