I want to place whole c file to ITCM (.text and .rodata). I found option in Managed Linker Script---> Extra linker script input sections but it won't work.
Please see image.
Tried with different syntax but it won't work.
Hi Jtro-san
In MCUXpresso, you can use following "attribute section" option in c files.
__attribute__((section(".bss.$SRAM_ITC"))) int g_exampleValue;
__attribute__((section(".ramfunc.$SRAM_ITC"))) void examplefunc(void)
"SRAM_ITC" can be set from project setting-> memory.
In EWARM, you can use following linker setting in icf file.
define region TEXT_RAM_region = mem:[from 0x00000400 to 0x0003FFFF];
place in TEXT_RAM_region { rw object example.o };
T.Kashiwagi
