How to move code from flash to sram
1,016 次查看
Wayne2
Hi NXP team
I want to move some high frequency functions from flash to the sram, in order to running in the sram which can reduce the cpu loading.
But I found it only can modify it in the settings, if I choose the "Link application to RAM", it will push all the flash code to the ram.
If I use the "Extra linker script input sections", I don't know how to specify a cpp file and then compile .o file move it to the sram.
I also found the .ld file was generated, and couldn't edit.
Could you tell me how to modify the code?
Thanks!
标记 (1)
991 次查看
jay_heng
You can try MCUX FreeMarker, it can help you relocate part of object files to any RAM
MCUXpresso IDE下高度灵活的FreeMarker链接文件模板机制
992 次查看
jay_heng
994 次查看
EdwinHz
Hi @Wayne2
Please look into the following community post: https://community.nxp.com/t5/i-MX-RT/Relocating-code-from-FLASH-to-RAM-All-file/td-p/1220584
I believe it will prove very useful for your inquiry.
BR,
Edwin.
