How to added pwm support on lnux platform for rt 1052
635件の閲覧回数
seven1
HI,
I run rt1052 on linux platform, now need add the pwm function, but not found  the dts & driver file about pwm.please provide releted code .thanks.
3 返答(返信)
549件の閲覧回数
seven1
Thank you for your reply. This is still the issue. I want to directly write registers on LInux to configure the PWM function, which registers should I configure, and what values should I configure. The more detailed, the better.
This pin is MXRT105X_ PAD_ B1_ 15_ GPIO2_ IO31, mean is MXRT105X_ PAD_ B1_ 15_ FLEXPWM4_ PWMA03。
535件の閲覧回数
Hui_Ma
Customer could refer RT1050 SDK software provided PWM demo, which uses eFlexPWM to generate A-phase pwm, B-phase pwm and C-phase pwm through submodule 0, submodule 1, submodule 2.
Related demo located at ..\SDK_2_13_0_EVKB-IMXRT1050\boards\evkbimxrt1050\driver_examples\pwm
Wish it helps.
best regards,
Mike
620件の閲覧回数
Hui_Ma
Unfortunately, NXP provides MCUXpresso SDK package for RT1050 product, not support ucLinux.
Please check with EmCraft about ucLinux BSP for RT1050.
Wish it helps.
Mike
