Can't get LPSPI example working on i.MXRT1064 EVK
1,043 次查看
langrind
I am using MCUXpresso with the i.MXRT1064 evaluation kit.
There is an SDK example called `evkmimxrt1064_lpspi_interrupt_b2b_master` which uses LPSPI (specifically LPSPI1.)
I don't have two boards, so instead I hooked up a logic analyzer. At this point, I just want to see the signals change state. The LPSPI master should be able to drive Chip Select low even if a slave isn't physically present.
When the example runs, the logic analyzer sees no activity on any of the four signals.
The i.MXRT1064 EVK brings `GPIO_SD_B0_00 - GPIO_SD_B0_03` out to J24 positions 6,3,4,5.
To set up IOMUX control to use the above pins:
  IOMUXC_SetPinMux(
      IOMUXC_GPIO_SD_B0_00_LPSPI1_SCK,        /* GPIO_SD_B0_00 is configured as LPSPI1_SCK */
      0U);                                    /* Software Input On Field: Input Path is determined by functionality */
  IOMUXC_SetPinMux(
      IOMUXC_GPIO_SD_B0_01_LPSPI1_PCS0,       /* GPIO_SD_B0_01 is configured as LPSPI1_PCS0 */
  IOMUXC_SetPinMux(
      IOMUXC_GPIO_SD_B0_02_LPSPI1_SDO,        /* GPIO_SD_B0_02 is configured as LPSPI1_SDO */
  IOMUXC_SetPinMux(
      IOMUXC_GPIO_SD_B0_03_LPSPI1_SDI,        /* GPIO_SD_B0_03 is configured as LPSPI1_SDI */
Trying different pad configurations (pull up, drive strength) didn't make a difference.
I think I am missing something basic! Any advice appreciated.
Nik
994 次查看
kerryzhou
Hi Nicholas Langrind ,
   Do you weld 0 ohm resistor to R278, R279,R280,R281?
  Where is the test point you have connected to your  logic analyzer ?
 No signal, should be caused by no connection to the RT chip related pins.
Wish it helps you!
Kerry
995 次查看
kerryzhou
Wish it helps you!
Kerry
994 次查看
langrind
Hi Kerry,
I did not look see the DNP on the schematic. This is the explanation.  Thanks very much.
(Hmm... I didn't read the example's documentation closely enough either. My bad.)
All the best,
Nik
