Câmera Cmos RT1050
Câmera Cmos RT1050
1,779 次查看
rubensjunior
Dear collegues,
Can anyone help me with an example of image capture with Cmos camera in Cpp language for RT1050? In the NXP SDKs there are only examples in C language.
Thanks a lot.
Rubens Júnior
1,647 次查看
FelipeGarcia
Hi Rubens,
I used MCUXpresso 11.1.1 and SDK 2.7.0. I double checked the project that I attached previously and it is working correctly on my side. I am also using MT9M114 Camera Module.
Could you please give me more details about what worked wrong means?
Also, could you please try to program same example straight from the SDK? Does it work?
Felipe
5 回复数
1,647 次查看
FelipeGarcia
Hi Rubens,
I have made an example using evkbimxrt1050_csi_ccir656 demo from our SDK but in a new C++ project for your reference. Please refer to the attached project.
Hope it helps!
Felipe
1,647 次查看
rubensjunior
Hi nxf46115‌,
I am testing your project and then I will tell you the results obtained. Thank you very much for your attention!
Rubens Júnior.
1,647 次查看
rubensjunior
Hi nxf46115‌,
I tried to run your project on MCUXpresso 10.3.1 with SDK 2.6.1 but work wrong.
In addition, I tried to run your project on MCUXpresso 11.1.1 with SDK 2.7.0 and it also worked wrong.
So, let me know which versions of MCUXpresso and SDK you used to implement your project.
I am debbuging in a evaluatin kit board EVKRT1050-EVKB with a cmos camera mt9m114.
Thank you very much and best regards!
Rubens Júnior.
1,648 次查看
FelipeGarcia
Hi Rubens,
Felipe
1,647 次查看
rubensjunior
Hi nxf46115‌,
I believe I had a problem with the installation of the SDK, as I reinstalled and your project ran perfectly in IDE 11.1.1. So there were no problems with your project, but problems with my environment. I thank you very much for the project, it will help me a lot to understand how to use the Cmos camera in conjunction with the NXP processor. Regarding the SDK sample project for using the Cmos camera, it works correctly in my environment, but it is written in C language, and I need to work in C ++ language.
Thank you one more time!
Rubens Júnior
