driver_examples\flexspi\nor\polling_transfer
There is no write enablement in the flexspi_nor_flash_erase_sector program,The original program is:
It should be written as the following program, the section in the red box needs to be addedotherwise the erase sector will not succeed.
Hi Op Fancy
Thank you for your interest in NXP Semiconductor products and
for the opportunity to serve you.
Thanks for your reply, I'd like to do a test by myself to replicate the phenomenon you mentioned, so whether you can tell me which RT chip you talk about.
TIC
i.MX RT1050
