1176双核调试
1176双核调试
1,110件の閲覧回数
jingyangxie
Contributor V
IAR开发环境,是否有imxrt1176使用J-Link调试器双核调试的配置或方案,双核无关联同时调试测试是OK的,但想实现如官方Demo那样使用DAP调试,主核启动从核,同时调试方式(主核工程设置从核工程路径)
4 返答(返信)
1,094件の閲覧回数
Hui_Ma
Please refer the AN13264 [RT1170 Dual Core Application] Chapter 4.2 about IAR dual core debug.
Wish it helps.
Mike
1,075件の閲覧回数
jingyangxie
Contributor V
I refer the AN13264 [RT1170 Dual Core Application] Chapter 4.2 about IAR dual core debug.but after the third step, the "attach the running target" label become gray and can not be clicked. like :
and the m4 can not be debugged
1,062件の閲覧回数
Hui_Ma
Hi, I am using the IAR ARM V9.30.1, I am using below steps:
The steps for dual core debug by JLink are as below:
1. Build CM4 and CM7 projects.
2. Start CM7 debug session.
3. Run the CM7 project.
4. Run/Debug the CM4 project.
I also find the [Attach to Running Target] button is gray.
Thanks for the attention.
1,059件の閲覧回数
jingyangxie
Contributor V
Looking forward to your updates.
タグ(1)
