已解决! 转到解答。
Hi Edouard
for second ethernet port one can try enet accessory cards (like IMX-RMII-BRPHY with TJA1100) described on
for software use fsl-imx8qxp-mek-enet2-tja1100.dts
Default nxp bsps do not support DP83867, one will have to port it, use its driver
Hi Edouard
@igorpadykov : thanks for the answer. Can you be a bit more explicit with what I need to do to "port" the DP83867 driver you provided in the link ? Is this a complex task ? I could rebuild the yocto distribution that is mentioned in my initial post. How do I add the driver to this ? Do I need to create a new yocto recipe; or add it to an existing recipe ? How do I "plug" it into the kernel ? Is there some files from the filesystem to modify ? I know very little about drivers in Linux... Any examples or guided walkthrough would be greatly appreciated...
Thanks for your help.
Hi Edouard
regarding porting new driver, unfortunately it is not simple task. NXP has special
service for help with porting new drivers: https://contact.nxp.com/new-prof-svcs-sw-tech
As general documentation one can refer to i.MX Porting Guide
