uuu stuck on 99%
uuu stuck on 99%
1,837 次查看
allonli
IMX8MPLUS platform
DDR stress test pass successfully.
build flash.bin standalone
"uuu.exe -b emmc flash.bin" stuck on 99%, UART no log output.
is there any debug method for such situation?
7 回复数
1,833 次查看
allonli
ps:add -V parameters, it show error below:
99%libusb: error [windows_transfer_callback] detected I/O error 1167: [1167] 设备没有连接。
1:11>Okay (1.libusb: warning [winusb_get_device_list] could not detect installation state of driver for 'USB\VID_1FC9&PID_0146\6&17382A9&0&1': [3758096907] 设备实例不在硬件树中。
1,827 次查看
igorpadykov
Hi Allon
one can recheck if uuu version is compatible with flash.bin,
recommended uuu version is described in Release Notes document of each bsp:
https://www.nxp.com/design/software/embedded-software/i-mx-software/embedded-linux-for-i-mx-applicat...
1,819 次查看
allonli
Hi,Igor,
  yes, I use the uuu version as release note described, but same erro.
1,806 次查看
igorpadykov
one can try on other computer.
1,801 次查看
allonli
yes, have tried.
and also test under Ubuntu system, the same result, but no "winusb" error message even add -V option, just stuck on 99%.
1,794 次查看
igorpadykov
could you try to reproduce issue on i.MX8M Plus EVK.
1,768 次查看
allonli
Hi, Igor,
Sorry,It should not be a uuu tools issue, cannt reproduce on EVK.
It may be customerize hardware or software problem, when stuck here, what's the possible problem, or how to debug it?
thanks a lot.
