source.codeaurora.org is closed, where is the nxp source code ? how to search in new address?
17,736件の閲覧回数
gonewithwind-peter
Senior Contributor I
for example, where is the below one:
https://source.codeaurora.org/external/imx/imx-optee-client.git/
how to search in new address, there are many page need to change?
I am using maaxboard-sumo and maaxboard-mini-sumo. I tried to search by keywords imx-optee-client
not found
https://github.com/nxp-imx-android
Thank you
17,727件の閲覧回数
brian14
Hi @gonewithwind-peter,
NXP did a source code migration from CodeAurora to GitHub.
Now, you can find any source code at the following link:
nxp-imx · GitHub
Also, here is the link to imx-optee-client:
GitHub - nxp-imx/imx-optee-client: i.MX optee client
I hope this information will be helpful.
7 返答(返信)
16,237件の閲覧回数
mushan
Hi where is the source code after source code website closed, like
https://source.codeaurora.org/external/imx/imx-manifest -b imx-linux-sumo -m imx-4.14.98-2.0.0_ga.xml
how to search it on nxp/github?
thank you
16,227件の閲覧回数
gonewithwind-peter
https://github.com/nxp-imx/imx-manifest -b imx-linux-sumo -m imx-4.14.98-2.0.0_ga.xml
I tired, It worked.
but inside ,many receipt not changed, many works to do. it's hard,if your are new use to run blitbake.
I directly backup my old source Downloads folder and never run bitbake cleanall so that I can use the already downloadsed source source code.
I
17,728件の閲覧回数
brian14
nxp-imx · GitHub
914件の閲覧回数
weidehai17
repo init -u https://github.com/nxp-auto-linux/auto_yocto_bsp -b release/bsp33.0  -m aa-integration.xml
repo sync
fatal: unable to access 'https://source.codeaurora.org/external/autobsps32/meta-aa-integration/': Could not resolve host: source.codeaurora.org
then,
repo init -u https://github.com/nxp-auto-linux/auto_yocto_bsp -b release/bsp38.0  -m aa-integration.xml
repo sync
Always stuck in:Fetching: 0% (0/9) 1:16 | 2 jobs | 1:09 meta-freescale @ sources/meta-freescale
Waiting for your reply,thanks!
858件の閲覧回数
gonewithwind-peter
but
I can download
Fetching: 100% (9/9), done in 20.164s
Checking out: 88% (8/9), done in 1.208s
repo sync has finished successfully.
~/work/test$ ls
nxp-setup-alb.sh sources
~/work/test$
please try to init you repos correctly to do again
13,197件の閲覧回数
vinisha_k_r
In case of https://github.com/nxp-imx/imx-manifest.
The issue still continuous. once the git link (https://github.com/nxp-imx/imx-manifest) is updated later on new error occur as can be seen below:
Error message:
fatal: unable to access 'https://source.codeaurora.org/external/imx/aosp/platform/bootable/recovery/': Could not resolve host: source.codeaurora.org
This again is based on source.codeaurora.org website.
In the provided git link we have verified the "imx-automotive-11.0.0_2.5.0.xml" file and have seen the hyper links are based on source.codeaurora.org.
 I request to provide some suggestions to resolve this issue.
13,172件の閲覧回数
gonewithwind-peter
right!
inside , there are lots links are still to source.codeaurora.org.
so  we hope NXP can solve this issue. it's hard to us to solve it one by one.
up to now. I have to backup all Downloads folder and never use bitbake -c cleanall ... to do. so we can keep my old building image.
