question about UART sending on imx257
1,115 次查看
bwq
Hello
I am a new hand on imx257.
Now I want to make some simple UART test code on imx25 PDK startkit. What I want to do is just send out some data on UART_1. (no interrupt, no CTS, no RTS, very simple...)
The test code is as below:
// UART Init
UCR2_1_bit.SRST = 0; //reset
UCR1_1_bit.UARTEN = 1;//enable UART
UFCR_1_bit.RFDIV = 5; // Divide input clock by 1
UCR2_1_bit.IRTS = 1; //ignore RTS pin
UCR2_1_bit.WS = 1; //8 bit
UCR2_1_bit.TXEN = 1;
UCR3_1_bit.RXDMUXSEL = 1;
UTXD_1 = 0x000000AA;
Currently, the FIFO empty flag became 0, but I can not catch any data by oscilloscope on UART1_TXD pin. Can anybody tell me is there any setting should I do for UART sending?
标记 (2)
6 回复数
935 次查看
jimmychan
935 次查看
bwq
Dear Jimmchan
I'm sorry. I'm afraid I can't read your previous message.
Ben
在 2013-07-25 17:02:41,jimmychan <admin@community.freescale.com> 写道:
reply from jimmychan in i.MX Community - View the full discussion
Reply to this message by replying to this email, or go to the message on Freescale Community
Start a new discussion in i.MX Community by email or at Freescale Community
Following question about UART sending on imx257 in these streams: Inbox
935 次查看
jimmychan
How about the IOMUX setting?
935 次查看
bwq
In the reference manual, it said:
000: Select mux mode: ALT0 mux port: TXD_MUX of instance: uart1.
So I use default value (0x000) for IOMUXC_SW_MUX_CTL_PAD_UART1_TXD:MUX_MODE.
Is this correct?
在 2013-07-25 17:38:42,jimmychan <admin@community.freescale.com> 写道:
935 次查看
jimmychan
Please enable the clock for UART. Please check the Clock Gating Control Register (CGCR) in the CCM module.
935 次查看
bwq
Hi Jimmychan
The clock for UART has been already enabled in function '__arm void low_level_init (void)'.
// configure peripheral enables for CGCR0
CGCR0 = 0x1FFFFFFF;
// configure peripheral enables for CGCR1
CGCR1 = 0xFFFFFFFF;
// configure peripheral enables for CGCR2
CGCR2 = 0x000FDFFF;
Is there any other register should I set?
在 2013-07-25 16:19:38,jimmychan <admin@community.freescale.com> 写道:
