openssl cryptodev engine on imx8mp
greeran
hi all
i am working on the imx8mp. i would like to secure my private keys and be able to use openssl without exposing the private key to userspace. i read that its possible with cryptodev openssl engine. i built the BSP with yocto and added the cryptodev-linux cryptodev-module.
i am able to modprobe cryptodev
but when i test for engines (openssl engine) i do not see the cryptodev engine.
those the imx8mp support cryptodev openssl engine and if it does then how to i add it to my openssl.
i am building yocto krikstone  5.15.71
thanks
Tags (3)
greeran
hi
i found my mistake. i needed to add the openssl-engines to the image-install
thanks
Harvey021
Hi @greeran
You need to follow up the Linux User guide as the chapter 10 security where you will find how to deploy it into rootfs using Yocto.
https://www.nxp.com/docs/en/user-guide/IMX_LINUX_USERS_GUIDE.pdf
Harvey
greeran
thanks for the reply
i did what the user guide recommended but with not success.
i had to add the packageconfig =" cryptodev-linux" (something that was missing in the guide.
i added cryptodev-module openssl-bin to the image install.
i see the cryptodev module in my bsp but i do not see the engines-3 directory from the openssl. i see it in the sysroot-destdir but its not installed in the image rootfs.
could you point me what i am missing
thansk
greeran
hi
thanks
