onnxruntime inference fails on I.MX8M Plus
912 次查看
mbrundler
I built an I.MX8M Plus target image as well as the eIQ Machine Learning SDK, using yocto with the imx-5.10.52-2.1.0.xml manifest.
I use the sample C++ application provided by ONNX Runtime ( C_Api_Sample) and slightly modified it to do an inference on a simple model (in .onnx format) that uses only standard layers (only 2d convolution, batch norm, relu and maxpool). Our modified source is attached.
Executing it either in default mode (cpu) or with the Armnn execution provider produces the expected output tensor (i.e. the differences with the reference output tensor are only a matter of precision).
However executing with the ACL, VsiNpu or Nnapi execution providers outputs a wrong output tensor.
This is surprising since changing of execution provider only impacts a single line of code (the call to OrtSessionOptionsAppendExecutionProvider_xxx and its associated #include).
Note the original C_Api_Sample.cpp with its squeezenet model behaves OK in all modes.
Any idea ?
891 次查看
Zhiming_Liu
Hi @mbrundler
Can you provide your error log?
Best Regards
Zhiming
