nnapi enabled tflite on i.mx8m nano results negative performance gain
423件の閲覧回数
Zack_Mak
I am testing the imx8mnddr4evk for tflite GPU acceleration.
As I know the i.MX8 nano uses NNAPI for GPU acceleration in tflite. However, in my test setup, the tflite shows negative performance gain when nnapi is enabled for tflite.
I also get the same observation when I run the tflite sample program (label_image) in NXP stock FW images.
The attached log file shows the sample code results from stock FW image version L5.4.47-2.2.0 imx-image-full-imx8mnevk. I ran the sample program right after flashing the FW image without any modifications.
Would you please verify my finding and advise if I have miss something?
Thank you very much.
388件の閲覧回数
joanxie
refer to your log file, when disable nnapi:
0.780392: 653 military uniform
enalbe nnapi:
0.784314: 653 military uniform
Python code, NNAPI enabled:
0.670588: military uniform
it seems the performance improved when you enable NNAPI, what negative performance do you mean?
