we want to add mipi_dsi support in uboot 2017 version on imx6dl board. I have found the following discussion but the link is unavailable it is giving error kindly check it once.
Patch to support MIPI display(hx8369) in uboot for i.mx6DL/DQ SebreSD boards
I have adapted the older uboot.2009 patch, support to mipi_dsi dsiplay and made mipi_dsi display up on uboot.2017. display is up and working. I have attached the modified patch here. It was made for MIPI 480x854 display with pix-clock of 27Mhz.
Hi Prasanna
one can try attached patch.
Hi igorpadykov,
The patch what you have suggested is very old it is for 2009 version u-boot. somehow I have tried to fit it on u-boot 2017 but it is not working.. is there any doc to describe how it's been implemented?
