I am want to use the Micron MTFC32GAZAQDW-AAT emmc which is an emmc5.1 with iMX6Q. But iMX6Q supports emmc4.41 is there any way I can use this emmc with iMX6Q?
Also wanted to know about the backward compatibility of MTFC32GAZAQDW-AAT emmc as it is not mentioned anywhere specifically that it will work as emmc4.41.
Thank You.
Hi @Rajan16,
I hope you are doing well.
One can refer to the link given below which may solve your query:
I hope it helps!
Thanks & Regards,
Ritesh M Patel
