hello,nxp friends
I want to use mfgtools to download imx8mm android images,while this tools need some script configurations,and only found linux image download configuration in nxp web,could someboddy give me a example。
by the way:mfgtools is support imx8mm android image download,i found uuu is a new tolls
thks
已解决! 转到解答。
Hi zhou
mfg tool is not more supported, instead uuu tool used:
GitHub - NXPmicro/mfgtools: Freescale/NXP I.MX Chip image deploy tools.
also please use Linux/Android documentation on
i.MX Software and Development Tools | NXP
Hi zhou
In the newest BSP NXP supply the uuu to download images, the uuu command is almost the same with mfgtool. UUU use command directly, take the windows system as an example:
• On Windows system, open the command line interface in administrator mode. The corresponding command is as
follows:
> .\uuu_imx_android_flash.bat -f imx8mm -a -e -u trusty
Here you can refer to our user guide. We have details introduction.
