map network drive
map network drive
947件の閲覧回数
snirnisim
hello everyone,
i have an issue while trying to map a network drive using the qsb.
my configuration is:
i compiled uboot,kernel and fs using ltib and installed samba (checked the start smbd nmbd).
i created a smb.conf file in /usr/lib as i understood from some manual.
the qsb is connecting to a laptop with eth.
everything is working well untill now.
i succeded to map a sata drive connected to the qsb in the connected pc running win7 and accessed the files.
now i'm trien to do the oposite action. i'm trying to share a folder from windows and access it from the qsb.
i've tried using the command: mount -t cifs //x.x.x.x/sharename but i'm keep getting error says: "mount: mounting //x.x.x.x/Maps on /mnt/win failed: No such device"
* the x.x.x.x is the windows machine ip number that i change here to x.x.x.x.
i also tried running that command on the linux host pc that i have ltib on but that finished succesfully, so something is wrong with the configuration on the qsb...
did anyone had this problem or have an idea?
thanks,
snir.
2 返答(返信)
832件の閲覧回数
snirnisim
well problem solved... just forgot to check network filesystems in kernel build... for cifs and smbfs...
832件の閲覧回数
snirnisim
i tried running smbclient -L x.x.x.x and got all shares, i can see the folder i'm triend to mount but i also get this lines in the end:
session request to x.x.x.x failed (Called name not present)
 session request to 10 failed (Called name not present)
session request to *SMBSERVER failed (Called name not present)
NetBIOS over TCP disabled -- no workgroup available
(again the x.x.x.x is the ipnuber that i changed to that after pasting here)
hope that will help someone to point the problem for me.
htanks,
snir
