login username and password failure
3,222件の閲覧回数
sanojkumar
Hi All,
I have been playing around with imx6q-SabreSD board for sometimes. I have compiled the source code with yocto for fsl-image-gui, I am able to flash and boot the kernel. However I am not able to login into the system. After wandering few websites and forums i did not find any default username and password for login (Someone says login:root & pass:<blank>). It  seems nothing is working here for me.
I have connected the HDMI with the board. Can anyone suggest me how to proceed with login. Or Can anyone tell me the correct login and Password?
I had compiled the source code with following command.
# bitbake fsl-image-gui
Sanoj Kumar
2,363件の閲覧回数
lijun
Hi Sanoj Kumar
     Did you do the right configure ?
     Yocto Training - HOME
     be attention to conf/local.conf, key word "MACHINE ??= 'imx6qsabresd'". if everything is correct, the username and password should be root.
     then if you still can not login you should paste your bootargs and your boot log.
     good luck!
John
4 返答(返信)
2,364件の閲覧回数
lijun
Hi Sanoj Kumar
     good luck!
John
1,481件の閲覧回数
vivsundar
Hi lijun,
I am not able to view the link in your comment: https://community.nxp.com/docs/DOC-94849
Should I get special privileges to access this document?
2,363件の閲覧回数
gusarambula
The username and the password both should be root. Have you tried this?
2,363件の閲覧回数
sanojkumar
Yes Gusarambula I did try root/root as username/password but still did not help me out .
