linux porting
linux porting
965件の閲覧回数
saida
hi
I have a customized imxdl hardware board where extra devices are added and pin muxing also different  from sabresd board
i am able to port u-boot,linux kernel and rootfile system with sabresd board which i purchased
in my custom board i am using uart3 and i chaned it in u-boot UART3_BASE ans CONSOLE is ttymxc2
so u-boot is working but kernel is not booting (i am using imx6dl-sabresd.dtb file for kernel booting which is in kernel)
it is stopping at 'Starting Kernel'
no further console messages
what could be the problem
thanks and regards
saida
5 返答(返信)
769件の閲覧回数
jingyangxie
Contributor V
Hi,Saida S
     Have you configed the gpio for uart3 correctly in the dts?if so ,you can do the test(communicate with the PC by read/write the uart)
769件の閲覧回数
saida
Thank you for your replay
I changed gpio pins for UART 3 in dtsi file and it is updated in dtb file after build also
But still it's not working. Where this UART 3 initialized in Linux ? I am debugging through source code also , if you have any clues plZ share it i will try and come back to you
Thank you very much
Saida
769件の閲覧回数
jingyangxie
Contributor V
the whole uarts will be initialized when enabled in dts.for imx,the uart driver is in /driver/tty/serial/imx.c.you can refer the file for details.or can you give the start massage of your board?I want to know more details.
769件の閲覧回数
saida
Ok i will send it to you soon
Byee
769件の閲覧回数
b36401
You need to update u-boot options with new console and make sure that Linux kernel itself supports it.
Victor
