linux-3.10.17 beta on sabresd does not reboot
1,245 次查看
phdm
On the same sabresd board, I have linux-3.14-rc4 where 'reboot' works perfectly, and 3.10.17 beta where 'reboot' does not work.  'mxc_restart' in both kernel is similar, and after having replaced  pr_err by pr_emerg for that message, with 3.10.17 beta I get 'Watchdog reset failed to assert reset'.  What could be the reason ?
标记 (4)
831 次查看
phdm
This is solved now.  IIRC it was a conflict in the dtb file.
4 回复数
832 次查看
phdm
831 次查看
johnlee
Hi, Philippe
   I have the same problems, could you speak in detail on how to fix it? Thanks.
831 次查看
YixingKong
Senior Contributor IV
Philippe
We have not got your response yet and will close the discussion in 3 days. If you still need help, please feel free to reply with an update to this discussion.
Yixing
831 次查看
YixingKong
Philippe
We are sorry for getting back to you so late. Are you still stuck with the issue? If you have somehow resolved the issue, can we close the discussion? If you still need help, please feel free to reply with an update to this discussion.
Yixing
