Hi anyone,
In imx_porting_guide.pdf, there is a description about porting SC FW,
'''A Yocto Project layer meta-imx-scfw is available to build the system controller firmware
from teh System Controller porting kit.'''
can anyone share how to fetch this yocto layer? it will be help to full firmware intergration.
Solved! Go to Solution.
Hi Igor,
Based on meta-arm, I have porting this completed.
check out firmware-imx and imx-sc-firmware
Hi yellow_huang
I am afraid this yocto layer is not publicly available, as this is internal software.
Available is "SCFW Porting Kit" on link
