inflexion ui plugin
inflexion ui plugin
597 次查看
Lyven
Hello all
I try to load the plugin from the demo into my own inflexion ui appliciaton. I add a plugin to my root.template. I refer through Resource->event handler = "demoPluginElement://" to my  ifxui_plugin.plugin file. In the editor the sinewave.png is visible (so I think the reference is good). However when i start up my application on the imx53 QSB, nothing appears. I just the exact same module code from the example and I made the integration layer with my UIintegrator.exe.
I think it has something to do with the startup of the element itself. (Since I checked which functions works with printf()). So I added a touchregion which tried to start the element. which got the IFX_RETURN_STATUS IFXM_ifxuiplugin_ExecuteLink_ButtonLink() function working but still nothing to see on the screen.
Anyone has an idea?
thanks in advance
kind regards
Lieven
标记 (1)
553 次查看
PhilBrumby
This query is currently being dealt with in the InflexionUI Community.
http://communities.mentor.com/mgcx/message/27682#27682
Phil.
