imx8qm jailhouse
imx8qm jailhouse
1,284 次查看
Ahelion
Hi all,
Is there any document showing all the steps to have a demo running on imx8qm mek board with jailhouse?
I was going over this: L5.4.70_2.3.3_LINUX_DOCS
but all I could find is a reference to device trees:
Hypervisor Jailhouse Enables the Jailhouse Hypervisor device trees.
• imx8qxp-mek-root.dtb: DTB for root-cell
I do not know what to do with this info. That is why I need a step by step instruction list.
Br, Mircea
标记 (1)
7 回复数
1,264 次查看
Rita_Wang
Which version BSP are you want to use?
1,260 次查看
Ahelion
L5.4.70_2.3.3, i was following this quide, so all bsp-s mentioned here I am using.
1,257 次查看
Rita_Wang
OK, I will help confirm.
1,173 次查看
Ahelion
any ideea?
Found out that the latest linux kernel does support the lates XEN
How can I get Linux and Android running at the same time?
1,155 次查看
Rita_Wang
Yes, the xen is supported on the i.MX8QM.
You can refer to the attach document.
Wish you have a nice day
Best Regards
Rita
1,149 次查看
Ahelion
I can tell you right now, it is not supported. I could not get jailhouse or xen to work on imx8qm. Whatever documentation i find is referencing linux4.9, which can not be build anymore.
653 次查看
Jerry137207
Hi, Ahelion:
I'm interested in runing multiple OS based on jailhouse, but related information is lack. I've sucessfully run jailhouse test demo in Imx8qm mek board. If you would like share info each other, plz email me: 1372071341@qq.com.
